Windscreen washers not working
Nevets
Re: Windscreen washers not working
Post by Nevets » Wed Sep 19, 2012 6:16 pm
Asda Bongo wrote:Are you sure that they are on different fuses. I makes sense to have the washer pump and the wiper on the same fuse. I am sure I read somewhere that that is the case. If it isn't can some one tell me which fuses before I take the bongo to bits again. I am just about to send off for a pump that will fit the front, but cannot find one for the back washer. I was thinking of buying 2 front ones and cobbling together a connection for the rear one. Also does the MOT require both front and rear pumps to be working?
Thanks for your help.
Just been out to check the fuses, its the 2nd row down number 7 across(from the left) and it does protect both the wiper & wash circuits
hopefully a new pump will sort [-o<
Also the rear wash n wipe is not an MOT fail :wink: but the front IS a fail ....
cheers Steve.
I am the only bongo in the village.......(not anymore there's two of us now "Damn it)
Nevets
cheers Steve.
Post by g8dhe » Wed Sep 19, 2012 7:10 pm
The front washers and pump are on this fuse (Hover mouse over fuse);
the rear ones are;
Image Spherical Visions
Post by Ian » Wed Sep 19, 2012 7:38 pm
I can also confirm that the front and rear pumps are different, but look interchangeable with a mod. I took delivery of 1 of each today.
Asda Bongo
Post by Asda Bongo » Mon Sep 24, 2012 9:43 pm
The front washer pump
Front Windscreen Washer Pump Ford Fairlane 76-03
fits and works a treat.
What pump will fit the rear washer bit. I am sure this front one could be manipulated to fit, but to save the hassle of rewiring etc is there one that will fit to replace the rear pump. At least I will get through the MOT and I should be able to replace the rear pump without having to take everything to bits again.
