No Go Bongo.
Re: No Go Bongo.
W'hooo Munkey's on the move . Have a great weekend and relax
Bongo no more........... ;-(
Re: No Go Bongo.
Great news - every Bongo cloud has a silver lining Hope the test drive goes OKmister munkey wrote:I am indeed.The Luckiest Man Alive
Picked it up half an hour ago, drove three miles home & all seems well. Didn't need the head off, cost £120 to get sorted, RESULT!!!!!
No time to post much right now as I'm packing up for a tiny test drive to Angelsey & late already.
- mikexgough
Re: No Go Bongo.
Nice outcome Chris....
- helen&tony
Re: No Go Bongo.
I have to add to that...I really am pleased for you...A nice cheap fix....and a smile from the Munkey Mascot...he'll be as chuffed as a chimp with 2 tails
Re: No Go Bongo.
Funny chimps in Bulgaria - Africa's don't even have one tailhelen&tony wrote: a chimp with 2 tails
- friendeedebs
Re: No Go Bongo.
Glad you got the bongo sorted and made it to Anglesey Hope you got back ok too
Debs
Debs
- mister munkey
Re: No Go Bongo.
Cheers gang. More often than not I find you guys to be a lot better than the Samaritans!
Dunno the techie talk but it was explained to me what went wrong, this is how I interpreted it . . .
There are 5 caps that hold the camshaft in place, each has a bearing inside - I think. On the front one, the bearing had failed leaving the camshaft to spin rather too freely & eventualy snap.
Chief Engineer timed it up & put it back together using parts from Maxs' old head, firing it up without the rocker cover to make sure oil was getting up where it should & noted that the oil feed to No 1 clynder takes 5 or 6 seconds longer to spurt out than the others - although once flowing the feed seems strong.
Advised to have a 15/20 second tickover at start up in the morning before wringing its neck up the road to give the oil a chance to circulate.
Re: No Go Bongo.
Great news MM - glad its sortedmister munkey wrote:Cheers gang. More often than not I find you guys to be a lot better than the Samaritans!
Advised to have a 15/20 second tickover at start up in the morning before ringing its neck up the road to give the oil a chance to circulate.
Re: No Go Bongo.
Was good to see you could all make it on Friday also with Bongo .xx
- helen&tony
Re: No Go Bongo.
hi John
No..course they haven't ...as regards the Bulgarian Chimpanzees, they are all in Parliament...same as most other countries
- mister munkey
Re: No Go Bongo.
Bumping this in memory of the magnificent Max Headroom and yet another fine example of how you guys go to extreme lengths to help each other out.
It's sad to see you leave us Nic, you'll be deeply missed.
