Fuse for brake lights
How do you remove a fuse from the fuse box. They seem to be stuck in there. The brake lights have gone and I think the fuse needs changing. I have tried new bulbs but that wasn'tthe problem
Bren
Bren
- crazy uncle gray g
Re: Fuse for brake lights
There should be a little (yellow) tool in the bottom part of the fuse box that grips them, or use some pliers to grip them.
At least it's SUPPOSED to... I discovered that the tool works better if you wedged the end of a flat ended screwdriver in at a jaunty angle in the "open, non fuse end".missfixit70 wrote:There should be a little (yellow) tool in the bottom part of the fuse box that grips them,
Remember you can test the brakelights with ignition off.
Hi,Check the switch on the brake pedal.
Cheers Mal..
Cheers Mal..
- You've Been Bongod
get some one to check if the brake light in the spoiler works when the brake lights supposed to be on
if that works and the brake lights on the bongo dont then its the brake light switch under the brake pedal
you can get them off ebay
If it is the switch, it probably just needs cleaning or moving/adjusting, can't remember what the bongo one looks like, but the one on my old espace had to be adjusted once or twice.
I had the same problem our lttle tool was in the fuse box and it was a black.
ATB
Kev
ATB
Kev
