Heat warning Light
Kazanne
Heat warning Light
Hi Guys, Can you help the heat light came on when I stopped I have a V6 Petrol 2.5 bongo friendee After i turned it back on a few minutes later it had gone off can you tell me whats wrong and if i can drive it to a garage to get it checked out. I didnt seem to have any problems when driving i only realised something was wrong when the light stayed on and it was bipping Thanks Kazanne.
Re: Heat warning Light
Dont understand !!Wot do you mean Heat Light.
Please clarify
Please clarify
SARAH & LIONEL - I Used to be Citroen 2CV "DOLLY" mad but BONGO-MAD lady with not so mad husband now!
Kazanne
The light on the dashboard drivers side according to handbook its calledExhaust Temperature Warning light but on the dash it just says heat!
I've never heard of that warning light before either....
Must be a new shape bongo thing....
Could you tell us if there were any symptoms being displayed when the the light was illuminated? For example, did the heaters still blow hot? Was the coolant level still full? Any steam,or peculiarities evident?
As an afterthought...Have you a switch fitted on the lower right hand side of the dashboard with a picture of an engine on it? If so, is it switched off? (it should be).
Could be a Bongo from the" cold part " of Japan !!!
Kentish Paul
Nothing to do with "New Shape". Mine does not have this. Could this be the mod to pre-warm the engine to ease starting in the north of Japan?
Bongo National Party - The law-abiding should have rights too!
Kazanne
We had just driven back from kent to westcliff about 30 miles it was fine when we went to kent and fine when we started home it was only when we stopped that it started bipping and the light came on its the same light as the scavanging fan light but without the battery symbol next to it. I looked in the handbook and thats what was written next to the warning sign. It was late when we got home and dark so will check the things u suggested and see what happens when we use it today. Also its a N reg Petrol so not the new shape. Thanks everyone. Bongo and out
Would you believe it. !!
Just checked it out,i also have a warning symbol that says HEAT.
Dont know wot it means though it always goes out when i fire up.
Perhaps its only applicable to V6 petrol engines
Is there anybody out there. HELP !!!
The heat sign i believe on start up is for a lamda sensor check
I think
I think
DOH !!
Thanks Cheffy34,
So as long as its *OUT* its alright,
Worry when it lights up as you are driving.
Have i got it right. ???
Thanks Cheffy34,
Not a new shape thing but a v6 thing i think BDCbigdaddycain wrote:I've never heard of that warning light before either....Must be a new shape bongo thing....
Dolly1 wrote:DOH !!
Thanks Cheffy34,
I think so dolly it should go out after bein fired up if it on when running the lambda is prob goosed, there should be other symptons lumpy running etc, over fuelling you know the score
cabte
could it be someone has fitted a coolant alarm and fitted the led at the back of the heat.
with it bipping ???
with it bipping ???
Kazanne
Hi Guys, I know i dont know much about mechanics of bongo but what is a lambda and what does it do ! Thanks Kazanne
Hi Kaz:
Its not a type of Dance that i know.
I might be wrong but here goes:The Lamda sensor keeps your fuel mix correct.
Know doubt somebody out there will put it in a more technical way.
