water in sill (I think)
Auntie-Freda
Hi My freda is normally parked on a slight incline facing up. Yesterday I parked on a steeper incline facing down. I noticed water dripping from where the front wing meets the sill (not from the doors) both sides more on passenger side. It continued to drip for some time, about an hour don’t know how much by volume but enough to reach the gutter and a drain a short distance away. I assume it was coming from the sill. Are Bongos prone to this. I’m worried because having large quantities of water sloshing around there isn't gong to help the longevity. Thanks A-F
Could it be from the rain gutter? Bongo roofs are pretty big,you'd be suprised at how much run-off you can get from a soaked roof...
If you own a bongolow, i think the pipe connected to the gutter from the sunroof,emerges somewhere near the front passenger side.
cynfal
My van has the same problem when parked on a road-mainly outside the house on an angle. And when it rains water collects in the footwell of which ever side is on the upperside of the slope. I have made 2 homemade ramps to level the van when parked outside the house and ive had no problems since
Gareth
Gareth
Auntie-Freda
Its not from the gutter. It was completely dry when this happened and I drove it for some time before I parked up. the water was definitely from inside the vehicle somewhere.bigdaddycain wrote:Could it be from the rain gutter? Bongo roofs are pretty big,you'd be suprised at how much run-off you can get from a soaked roof...
- dandywarhol
- dreamwarrioruk
also when you open the door check at a point between the two door hinges, on ours there was a missing blanking plug and rain had been getting into the sill area, it was strange when you braked you could hear water slossing around, waited till it was completely dry and then put in a new bung and its been fine for the last 2 years. just a thought to check.
Good point mike... Auntie-freda? Just a thought... If you normally park in a certain position (without any evidence of water) Then you parked facing the other way,can you recall if you'd driven in the wet the previous time you'd used the bongo? Even if it was a week previously...
The reason i say this is because, after driving in heavy rain (through puddles etc)the plastic undertray below the engine acts as a trough for water.
Mine spills onto the road as i accelerate away, after reversing down my drive,i reckon there could be three or four litres of water in the tray sometimes.
In addition, the aircon can release pools of water if activated.
there are 2 holes in the rear wheel arch at the end of the sill...I was alarmed at how much water was in my sills. I parked on a hill to drain out the water, tried to keep it dry and then sprayed waxoyl in and put some blanking grommets in.
Later when under the bongo I noticed some plastic plugs on the underside of the sill, does anyone know if these are for draining off water or filling with waxoyl etc.????
To make waxoyl really runny so it goes in all the nooks and crannies mix well with white spirit, the white spirit will evaporate leaving a waxy residue....or if you're a cock like me why not use diesel so the bongo stinks for weeks and weeks and weeks...and still stinks
. Runny waxoyl also goes everywhere...but not everywhere you'd like.....
Auntie-Freda
I am certainly struck by how easily puddles of water drop onto the ground from (I think) the point where sills meet rear wheel arch. Had it this morning as the frost melted off. I'm pretty sure though it was melted frost from the roof - its a big area and I think this is the route it sneaks down. Must investigate more fully one day.
WISHIHADABONGO
