On the fuel pump there's a Throttle Positioning Sensor which signals the autobox change up times depending on throttle position.
Mine was set quite far to the clockwise position of the adjustment so I marked the position, loosened the screws and turned it about 2mm anticlock - tried the Bongo and found I had turned it too far - it wouldn't kickdown above 60mph.
Turned it back 1mm and tried again. Seems to be good now - the upchanges on light throttle are smoother and earlier (but still revs to 4500 before changeup on full throttle) and doesn't drop 2 gears when kickdown is demanded at 60 mph.
I'm sure there's a setting somewhere for the TPS by using an ohmeter but I can't find it.............
Pete
