Fiamma carrybike - VW t4
If you have one of the VW racks and find that the small cup supports on the outer tubes do not rest on the bumper you can extend them using a readily available ,small ,solid rubber door stop. They fit neatly into the cup after removing the black felt . Fix in place with Araldite and screw back into the support tube.
