new to automatic gear box
I am hoping to take delivery of my Bongo this week - great!!
However, although I have had a short test drive, I have since thought of several basic questions and wonder if anyone can enlighten me.
1) do you engage neutral at traffic lights?
2) do you do hill starts from a drive position?
many thanks
many thanks
It really is so simple. Just stick it in drive and go. To stop you use the brake and stay on the brake at lights. To set off again hit the accelerator. It won't stall on you and the box will change up and down as needed automatically. After a week you will realise it is sooo much easier to drive than a manual.
I've been a manual man for 35 yrs too annsvan, but I dont want to go back now I've been Bongoed. You'll love it. Just make sure you tuck your left foot away from the pedals until you can be sure you dont try and depress the clutch pedal and end up slamming the brakes on.
Good luck with your Bongo
Mike
Mike
- daveblueozzie
This subject has been covered before annsvan. Please do not sit at lights with your foot on the brake. At best your brake lights will blind the motorist behind. At worst, your foot could slip off the brake. As you now know, an automatic will creep forward (or backwards if in reverse) of its own accord. Apply the handbrake and cover the brake with your right foot.
Advice is split between the pro's and con's of puuting the box in Neutral when halted. I believe it is not necessary and any wear on the clutch is offset by wear on the gearbox changing for a short period.
Finally, I have always been taught to use my right foot only. This is easy for me but then I have only ever driven an automatic. I did not learn to drive until I was 57 so wanted to fast-track the process. There is even a rest to park your left foot in most Bongos. However, there is a famous motoring journalist (Honest John in the Telegraph) who insists that it is highly dangerous to use only the right foot and that there are many cases of crashes caused by panic with the driver pressing gas instead of the brake. I suggest you use the traditional, one-foot technique.
Reading the forum and speaking to many Bongo owners it is clear that, whilst adapting to automatic is not difficlt , it requires as much effort to adjust than it would take me to learn to drive a manual.
With improving technology and traffic congestion, one day all cars will be autos.
box
box
Bongo National Party - The law-abiding should have rights too!
i had always driven manual cars until i bought galileo. however, jan had driven autos for years and gave me a couple of tips. in the end, i took gali off to the supermarket carpark after hours and indulged myself
so, keep your left on the stump and use only your right foot on the pedals, you will pick it up very quickly
welcome to the asylum
cheers
alex and jan
cheers
alex and jan
- haydn callow
Greetings annsvan,
Welcome to the madhouse,but its a nice madhouse full of nice helpful & friendly lunatics!!
Most of all enjoy your Bongo,and wave if you see me....maroon over silver 4wd Bongalow,vrm M***SHG,Winstanley/Pemberton area (sometimes with a caravan on the back)
Brian
Brian
thanks
Thanks to everyone for their helpful replies. I hope to get my van today from Wheelquick. Bongoplod I will look out for you, I will be grren over silver 2WD with chrome wing mirrors! R** WFV
Ann
Ann
