Its back at the garage now.
The breakdown chap tested the circuit about 15 minutes after the engine had started and he definitely didn't think they should be on for that long.
glowplug nightmare - bongo won't start
Re: glowplug nightmare - bongo won't start
- stilldesperate
- Tribal Elder
I wonder if the relay has welded itself shut?
Keeping the power to the glow plugs for that long wont do them any good.
Easy enough to test, good luck!
SD
SD
The garage are saying that they think its the relay control unit that's gone. Apparently they had alot of trouble getting the glow plugs out the second time.
Is the relay different to the control unit or would both need to be replaced (likely)
Ie
http://www.lushprojects.com/bongopartsm ... no=.html#6
does anyone have the relay or control unit lying around spare, cluttering up their house and desperate to get rid of...
Ie
- g8dhe
- Apprentice Bongonaut
Hi everyone does anyone know how to self test Mazda bongo glow plugs and could anyone tell me how I can do it thanks as I’m working on my bongo today and I’m trying to find a way of self testing the glow plugs
- g8dhe
The only obvious route to test a glowplug would be to power it up and see if it glows! So you would have to remove them and test each in turn, in which case its probably best to replace them all with new ones given that you won't know the age of the originals anyway.
If you don't have a tester for the glowplugs, you can look at the ends. As a rough guide, if the ends are black, they're not working well. But as I said, it's a rough guide.
Allan's closed. in Plymouth we recommend PGS (Plymouth Garage Services) or Mayflower Auto Services
