Flashing heater plug light.
Posted: Sat Sep 07, 2013 12:20 pm
by mikepvr
I have just fitted a new cylinder head, due to a crack inside number three exhaust post. Engine starts well and heater plug light acts as it should. Took it out for a test drive, water temp gauge rose to it's normal position and stayed there however after approx 5 miles the heater plug light started flashing and when I turned the engine off the cooling fan continued for about 5 mins. when checking the water level in the header tank it had ejected some water. Any ideas
Re: Flashing heater plug light.
Posted: Sat Sep 07, 2013 6:51 pm
by dom_e
Air lock in the coolant? Was it bled as per the instructions on YouTube?
I wouldn't have thought that would cause the heater plug light to flash though.
by the laird
Are the glow plugs new?
Posted: Sat Sep 07, 2013 7:19 pm
by Northern Bongolow
Posted: Sat Sep 07, 2013 11:05 pm
thinking about this more--------------.
is the glow plug rail shorting out on the top of the fuel link pipes from the injectors. check for rubbing carefully.
http://www.ebay.co.uk/itm/glow-plug-rai ... 2a3119bf0e.
when fitted wrongly this take a while to rub the plastic insulation off, then shorts, the front fans coming on is usual for the ignition off/direct short or low battery volts state.
Posted: Sun Sep 08, 2013 1:22 am
by mikepvr
Thanks everyone, the system was bled correctly and level has settled. The flashing light now only happens occasionally, so will check for shorting etc.
