Can anyone recommend someone in the Leeds area to look at a 3-way fridge, it's working fine on 240 / 12v, but badly on gas. (Or any suggestions as to the cause)
..... This is for a work colleague, so I don't know much more, but I think it's an Electrolux.
Thanks,
SD
3 way fridge repair
Moderator: Ian
- stilldesperate
- Tribal Elder
Re: 3 way fridge repair
Hi Just a thought, the van has to be level to work on gas. If its not working at all on gas itsstilldesperate wrote:Can anyone recommend someone in the Leeds area to look at a 3-way fridge, it's working fine on 240 / 12v, but badly on gas. (Or any suggestions as to the cause)
best to leave it to the professionals. Sorry dont know anyone up there.
Sometimes they have to be turned upside down to get the refrigerant to work. would't
try turning Bongo over though.
Good luck Brian
Definitely worth trying Brian's suggestion if its a portable fridge. Our old 3 way Electrolux stopped working on gas; turning it upside down for a short while, then upright again solved it.
Two tonne tin drum
- stilldesperate
- Tribal Elder
Thanks, guys.
I'll pass the tips on, and see how it does.
SD
SD
