Removing fuel pump because of leak.
Moderator: Doone
highlandjen
Post by highlandjen » Thu Feb 07, 2019 10:14 pm
I am new to bongos and mine is a ford freda. I have a diesel leak and was advised I need a new pump or refurb. They say they have to take the engine out and this is going to be £1000 . Is this right because I like my little freda but cant afford to spend all this on her. HELP PLEASE BONGO LOVERS!!!!!!!
Re: Removing fuel pump because of leak.
Post by Bob » Thu Feb 07, 2019 10:33 pm
Hi and welcome to the Forum. 8)
I've certainly never heard of the engine needing to come out to fix the fuel pump. :shock:
Certainly ADS, Aston Vale, Bristol, managed to fix mine without such drastic action.
I would be looking for a new, and Bongo Friendly, garage. A rough location will help someone recommend one. :wink:
Edit: This great post from Teenmal :-
viewtopic.php?f=3&t=73771&p=693052&hili ... al#p693052
Post by g8dhe » Thu Feb 07, 2019 11:02 pm
Also its often only the two simple seals which leak so see here as well;
viewtopic.php?f=3&t=15644
Image Spherical Visions
teenmal
Post by teenmal » Fri Feb 08, 2019 12:20 pm
highlandjen wrote: Thu Feb 07, 2019 10:14 pm I am new to bongos and mine is a ford freda. I have a diesel leak and was advised I need a new pump or refurb. They say they have to take the engine out and this is going to be £1000 . Is this right because I like my little freda but cant afford to spend all this on her. HELP PLEASE BONGO LOVERS!!!!!!!
HA ha,that reminds me "back in the day" we used to take engines Out to replace Spark Plugs.
Take care.
toudan002
Post by toudan002 » Sat Apr 11, 2020 3:24 pm
The issue now is that the maximum it will rev to is around 1800 rpm
ds8819
Post by ds8819 » Thu Sep 16, 2021 2:59 pm
toudan002 wrote: Sat Apr 11, 2020 3:24 pm
Did you manage to replace the fuel pump?
Also did you get the rev problem fixed? I have the same problem regarding unable to rev above 1200 rpm. I have changed the fuel filter which looked fine, no sludge, have used a biocide in the fuel tank in case it was a diesel bug, used injector cleaner additive but still no joy.
Wondering what to look at next. I'm convinced it's fuel starvation.... Fuel pump maybe?
