Ok, so this is probably something really obvious. However, I can't, for the life of me work it out. Bongonauts to the rescue please. The rear 'brake light'? won't turn off. It's the little red light on the back bumper. Any idea?
Thanks,
James
https://www.gumtree.com/p/campervans-mo ... 1184272093
Rear light won't turn off
Re: Rear light won't turn off
are you sure its not the fog light
which will have been done by importer as japanese dont use then
Yep, rear fog light with a very strange switch.
Thank you.
Thank you.
Fog should be wired so it only comes on when lights are switched on
You might want to get the wiring changed
So you don't flatten your battery
You should have a tell-tale/warning light on the switch, it is perfectly MOT legal to have it wired independently of the ignition or the side/head lights, just make sure that the light on the switch is working.
Good Luck.
Good Luck.
The many joys of the bongo
