V6 HT leads (again!)
Gripped
Post by Gripped » Sun Mar 24, 2019 11:21 am
Hi All
just got our "new" 2001 Bongo V6.
Overall, she seems solid and should be a keeper. However, she has a misfire, which I've diagnose to 2 HT leads which have broken down at the spark plug connection. A common issue I understand.
Anyway, as we are going to convert to LPG, my research tells me that I should go for the genuine Mazda kit. However, given the various quality after market options, (and the fact that the club also sell an aftermarket kit) I wondered if anyone had an update on how well these cheaper options last. It's been a few years since these kits have been around, so I thought there should be a good range of experiences by members on here. It seems logical, that a well made aftermarket lead should be able to be as good as or better than OE.
I note there are UK manufactured kits, which are meant to be OE or better quality. And significantly cheaper. :wink:
Finally, the Mazda OE kit from the club doesn't seem to include the king lead? Any ideas?
I will replace the rotor, dizzy cap and all the HT leads, plus spark plugs. Any advice on what kit to get?
Thanks as always !
Re: V6 HT leads (again!)
Post by teenmal » Sun Mar 24, 2019 1:22 pm
Never had a problem with this company.
https://www.ignitioncarparts.co.uk
mikeWalsall
Post by mikeWalsall » Sun Mar 24, 2019 3:37 pm
Same leads as I used on my V6 .. I suggest you replace .. or at least clean the terminals inside the dizzy cap at the same time ..
Gripped
Post by Gripped » Sun Mar 24, 2019 9:48 pm
Thanks for the replies.
What I'm after is feedback from those running LPG and using aftermarket HT lead kits.
Has anyone tried this one? It contains everything I need:
https://mazdabongo.com/product/mazda-bo ... ll-models/
Post by Ian » Sun Mar 24, 2019 10:20 pm
Here's an old discussion you might be interested in: viewtopic.php?f=3&t=67474&hilit=leads+genuine+mazda
Gripped
Post by Gripped » Mon Mar 25, 2019 11:49 am
Thanks Ian - that's great.
Definitely a useful thread, but from what it seems to say is that the Magnecor HT leads were ok (apart from incorrect label) and the likely issues were down to a faulty distributor?
I'm am fully prepared to get genuine Mazda parts - (particularly the distributor,) but in my mind, if there are "better than OE" HT leads for much less money, I'd prefer to get those. I was thinking of a combination of genuine Mazda dizzy and rotor, NGK sparks, and aftermarket (better than OE) HT leads.
I am prepared to take advice on this though !
Gripped
Post by Gripped » Tue Apr 02, 2019 5:30 pm
Ok, so I've reached a compromise (if only BREXIT was this easy).
Ordered genuine dizzy cap and rotor from the club shop, and went for Magnecor HT leads, on the basis that they are a quality item and cheaper. And I like blue. :wink:
Will keep you updated on how they perform on LPG.
