fridge
fridge
My 12v Waeco Coolmatic blew up on me last summer and I'm just getting round to replacing it. Couldn't believe it's going to cost me up to £650 for something I only use maybe 6 days a year. Can anyone suggest a cheaper replacement that won't be too much trouble to fit?
Re: fridge
I have a Waeco Tropicool which i bought 2nd before getting the Waeco CF18 compressor. Although its a Peltier type and not in the same efficiency league as the compressor fridge its still pretty impressive compared to yer average cheap Peltier type i think and now i have a 100w solar panel i might trial whether it can be used without flattening the LB. I might just get a surprise.bishops wrote: ↑Sun Dec 03, 2017 12:45 pm My 12v Waeco Coolmatic blew up on me last summer and I'm just getting round to replacing it. Couldn't believe it's going to cost me up to £650 for something I only use maybe 6 days a year. Can anyone suggest a cheaper replacement that won't be too much trouble to fit?
Re: fridge
Yup, they are an expensive bit of kit. More effective and quieter than a cool box and more pleasant than a case of botulism though. if you're not going to replace like for like you will need to consider the size of the hole it's going in.bishops wrote: ↑Sun Dec 03, 2017 12:45 pm My 12v Waeco Coolmatic blew up on me last summer and I'm just getting round to replacing it. Couldn't believe it's going to cost me up to £650 for something I only use maybe 6 days a year. Can anyone suggest a cheaper replacement that won't be too much trouble to fit?
Mark
- g8dhe
Re: fridge
When you say "blew up" there are normally spares available for the compressor unit which is a lot cheaper than replacing the whole unit. Do you know what's gone wrong with it ?
http://www.penguinfrigo.co.uk/12_volt_f ... ce_centre/
Re: fridge
And Penguin are in Havant so only just across the water from you!g8dhe wrote: ↑Sun Dec 03, 2017 5:34 pm When you say "blew up" there are normally spares available for the compressor unit which is a lot cheaper than replacing the whole unit. Do you know what's gone wrong with it ?
"Now open for business offering a unique drive up service for motor homes and campervans to get their DC compressor fridges and freezers checked, serviced and repaired at Penguin’s premises in Havant, Hampshire. "
Their £36 per hour labour rate's not at all bad either.
Mark
Re: fridge
There are other specialist Bongo conversion firms who might do the job as well. See the list over on the main Bongo Fury website at https://igmaynard.co.uk/conversions/
