Page 2 of 2
Re: Front end pimp
Posted: Fri Aug 19, 2016 10:46 pm
by Northern Bongolow
Gasy wrote:Moved my number plate
Auto gear box small rad cooler and stainless hoses ( just see it mounted in front )
New spot lights
Black wire mesh in front opening to protect rads
Looks cool I think
Shame some idiot smashed me front bumper up and paint is peeling awhile back
that little girl with the sack truck did well to get that tall post to the side of that inferior van behind you, but i dont think it will go in there.
the only reservation i have with a trans oil cooler is it will take a bit longer to get the gearbox up to temp to engage lock up in top so is it really worth it as you spend most of the time without yer caravan on the back.
Re: Front end pimp
Posted: Fri Aug 19, 2016 10:55 pm
by Bob
Good point, Ady, personaly I think it is worth it when towing 1.6 tons on a hot day but as always a trade off.
Re: Front end pimp
Posted: Fri Aug 19, 2016 11:44 pm
Got to be worth it. If any concerns then provide it with a cover except when towing the caravan. But if Alacrity says they're a wise investment when towing then for me that says it all.
Re: Front end pimp
Posted: Fri Aug 19, 2016 11:55 pm
by Bob
It would be simple to fit a bypass valve, but I wouldn't remember to switch it.
Re: Front end pimp
Posted: Sat Aug 20, 2016 8:36 am
by Gasy
I thought about it getting up to temp to hit top gear aswell
But it doesn't seem to make any difference
Goes into top at the same distance away from my house when I'm driving
As it did when I didn't have it
Re: Front end pimp
Posted: Sat Aug 20, 2016 8:40 am
by Gasy
And she didn't move the post NB
She lifted her dads van up onto kerb with the sack barrow
Tuff little buggers around here , they got a Russian accent
So she might have had a bit of training assistance
Re: Front end pimp
Posted: Mon Aug 22, 2016 7:00 pm
by Alkers
HAve you a link to teh cooler?
Re: Front end pimp
Posted: Tue Aug 23, 2016 10:20 am
by cmm303
Gasy wrote:I thought about it getting up to temp to hit top gear aswell
I'm sure I've seen on here a comment that the cold start gear holding might be determined by engine temp and your observation would back this up.
Re: Front end pimp
Posted: Fri Aug 26, 2016 2:17 pm
by Gasy
Alkers wrote:HAve you a link to teh cooler?
This one has different hoses to the one I used
But would be more suitable
All you need is 2 right angle brackets and screws for fixing and 2 jubilee clips
Ebay item number 371465121835
