low coolant alarm coming on
al & chris
Post by al & chris » Thu Mar 19, 2015 9:12 am
Ok twice now low coolant alarm has come on whilst driving. The alarm slowly comes to life light on, stays on for a while about 20 seconds second time longer first time then goes off. No coolant loss and no temp increase with TM2.
Thinking it could be earth or something?
helen&tony
Re: low coolant alarm coming on
Post by helen&tony » Thu Mar 19, 2015 9:24 am
When starting, or after a while?....
al & chris
Post by al & chris » Thu Mar 19, 2015 9:31 am
After a while. We do have the usual chirping when starting but this is on constant.
David Edwards
Post by David Edwards » Thu Mar 19, 2015 10:17 am
Take the screws out and either replace or give em a really good clean, happens with mine now and again.
helen&tony
Post by helen&tony » Thu Mar 19, 2015 10:36 am
As David said...plus check earth, and other connections etc.
Post by haydn callow » Thu Mar 19, 2015 11:24 am
Yep, try all the above first, please report back.
andyb36
Post by andyb36 » Thu Mar 19, 2015 12:19 pm
hi haydon
mines doing the same every now and then
touch cloth scenario when your on the motorway
stays on or flickers - then goes off
I think its prob the screw getting coated etc
I have never changed it
if I send you the funds - is it possible you can send me a replacement
also - MY BUZZER - DOESNT BUZZ - no problem because it was annoying - but my led still works
was this ever reported as a problem ?
thanks
andy
Post by teenmal » Thu Mar 19, 2015 1:24 pm
andyb36 wrote:hi haydon
thanks
andy
I would imagine that you would like this function to work properly, if its annoying its indicating that there is a fault IE lack of coolant in the header/expansion tank etc .
andyb36
Post by andyb36 » Thu Mar 19, 2015 1:49 pm
hi teemal
the alarm works fine - but only with the led
it flashes bright enough to get my attention straight away
in fairness - if the bulb went - I wouldn't be so happy - I would need the buzzer
but I do check its working ok every time I start her up
[-X
no fear there - I would have a new one on order as soon as it didn't flash on start up
andy
Post by haydn callow » Thu Mar 19, 2015 4:05 pm
thanks
andy
I doubt your problem is a dirty screw (always wanted one of those). Make sure level is o.k. Send your address though and a new clean screw will be sent by return ( it will be a bigger one ) regarding the buzzer...is your alarm unit cylinder shaped or cube??
al & chris
Post by al & chris » Thu Mar 19, 2015 10:08 pm
helen&tony wrote:Hi
Not checked anything yet apart from coolant level. looks like it could be earth or something as it did it again today but put indicator on to turn and it went straight off.
Post by haydn callow » Thu Mar 19, 2015 11:25 pm
Check the sensor screw is snug and the ring terminal is firmly in place.
andyb36
Post by andyb36 » Fri Mar 20, 2015 7:06 am
haydn callow wrote:Check the sensor screw is snug and the ring terminal is firmly in place.
pm sent haydon
cheers
andy
Post by haydn callow » Fri Mar 20, 2015 3:04 pm
New screws on the way!!
