hi all,
does anybody have one of these awnings? I'm thinking of buying one or a newer model of the Khyam Motordome classic awning that we already have. The Khyam is excellent apart from water leaking under the edges as there is no built-in or bath-tub groundsheet (it rained ALOT at the Battle of Hastings in October). The 2014 model does have a bath-tub groundsheet.....
I'm concerned that the centre air tube will block the way into the Bongo, going by the photos that is, and if the door can open fully without clouting the awning
TIA
Graham
Outdoor Revolution Oxygen 3 movelite awning
Moderator: Muzorewa
- Rocketscientist123
- Junior Bongonaut
- Simon Jones
Re: Outdoor Revolution Oxygen 3 movelite awning
I was looking at the Oxygen 2 version and that looked like it would be ok. Only negative was the size of the bag it comes in, but if you're used to the Kyham then it will be no problem.
