Snapped rear anti roll link in Portugal, parts?
eppiblue
Post by eppiblue » Thu Jul 25, 2013 11:45 am
Just realised I've snapped the linkage left rear. Question is, would this part be available on the continent given its from a bongo, in other words do other vehicle makes use the same links? If not I guess I need to order one online and have it courier over?
Thanks for your advice
'Vincent' - 1996 P reg - Green - 2.5 TD - 4WD - Likes: Diesel, Bitumen and Snow.
Re: Snapped rear anti roll link in Portugal, parts?
Post by teenmal » Thu Jul 25, 2013 1:09 pm
Check out the Compatible Parts Database, might help you.
helen&tony
Post by helen&tony » Thu Jul 25, 2013 2:30 pm
E-mail Ian for the bits from the Club Shop....he's expert at mailing bits for distressed Bongos....but in the mean-time, spray some WD40 over the area, as the bolts often are stuck in...do it several times while you await the parts
Post by Ian » Thu Jul 25, 2013 5:16 pm
I can send you one, no problem, just phone the office. There are various postage options available, but BE WARNED we will only offer this service to paid-up members of the club. After all you wouldn't phone the AA if you weren't a member, would you?
But you might be able to source one locally. The links are the same as on a Ford Galaxy.
Post by mikeonb4c » Thu Jul 25, 2013 6:56 pm
Ian wrote:I can send you one, no problem, just phone the office. There are various postage options available, but BE WARNED we will only offer this service to paid-up members of the club. After all you wouldn't phone the AA if you weren't a member, would you?
But are the brackets the same? You might get a garage to make one from mild steel in an emergency, and the bush by wrapping bicycle inner tube!
Velocette
Post by Velocette » Thu Jul 25, 2013 8:14 pm
Or maybe weld up the snapped one if it is the shaft.
eppiblue
Post by eppiblue » Thu Jul 25, 2013 9:48 pm
Thanks, ill get on to it. I'm a paid up member of bongofury, is that what you mean?
Emergency? Doesn't seem too much of an issue for now but would be good to get sorted. Am I doing any damage driving around without it fixed?
