AGM Minutes
Posted: Sun Jun 27, 2010 12:04 pm
Here's a brief report back from the AGM.
Matters Arising From 2009
Suppliers have been found for rear wheel arches (see http://www.igmaynard.co.uk/bongo/fox_archives.htm#body)
The members survey was conducted and results published in newsletter Edition 26 (see http://www.igmaynard.co.uk/bongo/member ... 3.htm#news)
The Bongo Relay and Bongpages services have been introduced.
Wiring manuals are now available for download ( see http://www.igmaynard.co.uk/bongo/member ... #databases)
Financial Report
For the year ending 31 March 2010 the club received £51,923 and spent £49,354. This left a surplus of £1,569. These figures do not include the Bongo Shop which is run separately.
Special Awards
Geoff Mather was given the Bongomaster's Special Prize for his work on the downloadable wiring manuals. Kirsty Elliot was a popular choice for Bongonaut of the year.
Disabled Slots at Club Meetings
It was agreed that 10% of available electric hook-ups (6 at Stourport, 7 at Bongo Fest South West) would be held back for 24 hours for people with special needs. If unallocated these would be returned to the general pool.
Rule Change
A new rule was introduced. (see http://www.igmaynard.co.uk/bongo/member ... .htm#rules for full revised rules)
Rule 1.1 (1) (e) If you are travelling in (or on) a non-motorised form of transport and you spot a Bongo, you should raise your arm and open and close 4 fingers over the thumb. This should be done in a bold manner so it is not confused with any other gestures.
The passing of this rule means that Rule 1.1 (1) (b) will be amended.
Any Other Business
There was a further proposed rule change, the introduction of Rule 1.1 (1) (f), which was what should the correct response be to rule 1.1 (1) (a)? This was deferred to the next AGM for full discussion.
An issue on vehicle security was raised and it was agreed that Bongo Mission Control would collect chassis numbers from 1 July on all new membership applications and renewals. This way a check can be carried out if Bongos are reported stolen.
Financial Report
Special Awards
Rule Change
Any Other Business
