new member with questions
Re: new member
I am gong to remove the cylinder head, diesel repair shop say cant be the pump as it is a rotary type and do not create this type of problem they either work or don't basically .So i am going down the road of a mechanical problem ie valve / cracked head but dubious as compression test was good but who knows what i will find pot of gold may be
Re: new member
Easy tiger you’re leaping straight in to the deep end if it’s cheap parts wise to try another pump to be sure of problem why not try it I have a pump that was perfectly ok for the cost of postage and a beer I would happily mail it to you. Also is there any difference compression wise between hot and cold
Re: new member
Also these pumps are responsible for the injection timing so they are reasonably complex to the point where they could be party to the problem unlike the common rail rotary pumps which purely just supply pressure
Re: new member
That sounds a good idea can you find out how much to post to WV4 6SU and how much on top and we can sort it out
Only checked compression cold
I have started to take it apart and i think someone has been ! tatting ! for want of a better word bolts not tight new jubilee clips and hoses easy to remove mainly things you would expect to be tight or seized if you know what i mean cheers.
Re: new member
I reckon £30 should cover it I could send it of Monday let me know cheers
Re: new member
thats good how can i pay cheers steve
Re: new member
I’ll pm you my bank details and you can tell me your address
Re: new member
That ok but call or text me on ********** if that is easier cheers
EDIT Phone number removed to lower the risk of you being spammed. Its better to share it by private message.
Re: new member
Thanks i did wonder about posting my number
Anyways i have removed the c/head and took to be tested and it is ready to collect on monday with no faults found
Put oil into the cylinders still there after 3 days no loss.
Pumps and injectors away to be tested will not know till next week i hope they find a problem because if not i will be stumped
After 50 odd years . Car / hgv / bus mechanic
Re: new member
Well engine back together but still not running rite i think i have a timing issue as when i rev there is a rattle at top end but not on tick over its mainly from the front cylinder no1 definitely worse starts first time. All injectors and pump tested ok
So do you think it could be timing one tooth out or valve adjustment .
Re: new member
Did it have a new belt on it when you got it
Re: new member
i have fitted a new belt / head skimmed tested / good compression / pump /injectors refurbished ect this why i suspect either valve clearance / or timing is out as it does sound like a detonation problem like a skeleton rattling in a tin can so to speak . The higher the revs the louder it gets.
Re: new member
I just wondered about the belt like if it was a new one on there someone might have done something wrong
Re: new member
Would be worth checking valve clearances again now you’ve run it up don’t know if there’s a hot gap setting or if it’s just from cold. From memory doing old ford engines those lock nut adjusters are a pain would have thought they would be hydraulic very primitive
Re: new member
I agree going to check valve clearances but go to check what the clearances are when weather picks up and re check timing but i am lead to believe you have use a dial gauge to do it properly cheers
