Hello all
I’ve got a bit of a problem with my Gearbox.
I have a 2002 Aero pop top 2.5 Diesel and when cold will not take off in D(rive) but will in L(ow). I can then put straight into D and it will carry on happily unless I stop at a junction and then I need to knock it back to L to take off. After it warms up a bit (2 minutes or so) all is normal again.
When I bought Minty the gearbox seemed a bit weird on the drive home so I decided to replace fluid and clean filter and ever since have had these problems.
I have checked fluid level in P after a 20 minute run with engine running after cycling through gears - any ideas?
I have read through all postings that I could find and on one someone mentioned ‘nipping up the drive belts’ does that sound like it might be it?
Anyway, any help would be most welcome.
Transmission problem
- Apprentice Bongonaut
Re: Transmission problem
Oh and I’m normally in Weston-super-Mare but this week I’m in Suffolk and Norfolk.
Hi, I'm no expert, but I can’t see 'nipping up the drive belts' helping.
ADS, Ashton, are pretty good with Bongos, but an auto box specialist should be able to help.
- g8dhe
Yup, the drive belts don't affect the gearbox at all.
Hello again, I’ve just found I misquoted mikeWalsall from 2012 - it was ‘nipping up the bands’ sorry, not belts.
User avatarmikeWalsall
Re: Auto transmission fluid drainage removal DIY suction dev
Post Wed Dec 26, 2012 4:48 pm
I popped into my local Auto gear box specialist recently .. (all they do is auto boxes no engine or general car repairs) ..
A fluid change on my Bongo would be £60 (+vat @20%) .. I assume that was a simple 'suck out of the dipstick tube' job ... when I asked how much for a full sump off service including filters .. nipping up the bands etc:, that price 'shot up' to £150 (+vat @20%)...!!
W
W
It’s a lot more work.
- g8dhe
Not the same sort of automatic gearbox I'm afraid! These don't have ANY bands to nip up!
http://www.g8dhe.net/bongo_images/Gearbox/RC4AEL.pdf
