Does anyone have any suggestions for the best way to route a waste water pipe (from sink) to the outside world?
Just wanting to see ways others have done it before drilling holes in my van!
Thanks!
Waste water outlet
Moderator: Doone
Re: Waste water outlet
Stating the obvious, this will depend on where the sink is fitted.
Your point is well made, though, you don't want to be drilling until you're 100% certain you have the best routing for the outlet.
Good point Bob!
I have a rear conversion so my sink is at the back so a routing to the back is what I'm looking at. I think if I could drill through the floor somewhere and have a flat container under the van, that would be good.
I was wondering, too, where rear waste water hole is best placed. Any suggestions please? Thanks
i have an Elite full side conversion. The waste pipe from the sink exits behind the rear wheel arch where the bumper wraps around. the overflow for the water tank is there too.
The flat container you're after is a 'wastemaster' - here's one on Gumtree:
https://www.gumtree.com/p/campervan-car ... 1308572448
I happen to have one going spare in North Norfolk - yours for 20 quid if you can collect it
Mark
