Hello all,
So, we're currently on our holiday in sunny post-hurricane Wales, happily unpacking our Bongo to move to another chalet after the first was infested with flies...
...when I notice oil patches behind the Bongo. Took a look underneath and sure enough - there are actual drips of oil coming down from the central block area under the Bongo.
Checked the dipstick, and we're still just under full. (Going to check it again in the morning.)
We've had leaks before, but only very small ones, not noticeable drips.
I've taken a couple of pictures to show an idea of locations. The drips were at around 5 second intervals. You should be able to click through the three photos here:
https://imgur.com/a/0JgsL
Any advice? We're basically trying to work out if this is a "find a Bongo mechanic immediately" scenario, or a "top up the oil till you get back and book it into the garage" situation.
Hoping this won't tip a 'challenging' holiday into a minor disaster
Thanks!
On holiday: bongo dripping oil
- Bongonaut
Re: On holiday: bongo dripping oil
Depends how far you are from home.
50 Miles likely fine, thousnad miles...
Also, could it be diesel? Looks very similar on the ground. Might be worth putting an old newspaper under it for a couple of minutes to check.
- Bongonaut
Thanks for the reply!
Sorry, forgot to say - it's a V6 petrol. We recently had the rocker tightened and the seals replaced.
We're almost 300 miles from home, sadly!
It would be worthwhile checking the sump plug/oil filter/oil switch for leaks and tightness , and checking the auto box fluid level would not go amiss.
- Bongonaut
Thanks for the advice!
I don't suppose anyone has experience of using Bar's Leaks for oil or power steering fluid? Seems to suggest it's a viable temporary measure, but unsure whether it's the healthiest stuff to put into a Bongo?
Cheers!
Cheers!
If the rocker gasket has recently been changed then it could have got pinched when installed. I think you will be OK if you top it up but see a proper Bongo friendly garage on return home.
Ideally take it to the garage that tightened but didn't replace the rocker gasket. Tightening is a bit of a hit and miss affair and doesn't really substitute for replacing it, sadly.
Can you put an old towel on the undertray to catch the oil meanwhile? I was able to do this when i had a dripping diesel fuel pump and it stayed in place fine.
- Bongonaut
Thanks all for the excellent advice. We called out garage and asked them to look into the gasket as soon as we return. Checking the dipstick in the morning, it had barely gone down at all.
I assume (and hope) that the problem looked worse than it is because the sheer volume of rain was bringing more water up into the underside of the Bongo and exaggerating the drip.
Thanks again!
Thanks again!
