cannot find out what the tyre pressures are in PSI in the book it says 180 front and 240 rear . can anybody help me?
it's an MX-6
I'm a newbie
- g8dhe
Re: I'm a newbie
An MX-6 ? This forum is for Mazda Friendee or Ford Freda not MX-6!
Re: I'm a newbie
It should give you a pressure on the side wall of the tyres
Re: I'm a newbie
I'm guessing that's 1.8 and 2.4 bar.
Don't worry if its a model not common on here, we're a friendly rabble.
26psi And 35psi are direct conversions.
If this is for a Bongo Friendee these sound about right for factory settings, but most peeps run a bit higher in the Uk.
Personaly I run 38 and 40psi.
Edit: The units will be kPa, directly related to bar.
