Gas hob
Moderator: Doone
Gas hob
Well Beryl has arrived, but I haven't a clue how anything works! Sat on the drive dying to make a brew and can't get the burners on, can't even locate a gas bottle ( if it has one) only what appears like an adapter on the outside? Is this the norm,do I have to put my gas bottle outside, help please my fellow bongonaughts
Re: Gas hob
Congrats on getting the Bongo.
Is it a side conversion?
Bottle(s) are normally in the wardrobe bit.
I would imagine the outside gas thingy is for an outside barby or something any chance of an image of the offending item?
You may be able to trace back from that pipe to the bottle.
- g8dhe
Re: Gas hob
Open the rear door, and look down the lower right corner often a small hatch behind which is the mounting for a gas bottle ?
Re: Gas hob
Only a fuse box in that cupboard,, it's also an lpg conversion if that matters,,,
- g8dhe
Re: Gas hob
Perhaps some pictures then, the trouble is everyone can be a bit different depending on what was wanted at the time!
- Bongonaut
Re: Gas hob
Don;t know much about your conversion, but in my side-conversion it's under the unit immediately behind the drivers seat - Standing outside the drivers door I fold the seat forward to access it.
Good luck, and enjoy the Bongo.
Re: Gas hob
Thanks everyone for the advice,, think I've sussed it with some advice from a VW colleague at work,, will keep you posted on the end results
Re: Gas hob
Good news.
Updates always welcome as info helps others.
Re: Gas hob
Sat having a brew even as we speak, what I thought of as technical difficulties I've been assured is only a learning curve!
Just to sort the leisure battery situation, how to fasten the awning, wait for the wife to 'decorate' and the upstairs mattress to arrive and I think Bob might just be my uncle
Re: Gas hob
Bob must have had a bike cos he is quite a lot of peoples uncle.Bob wrote:
