I agree. This characteristic of the BF Search engine has irritated me more than oncesotal wrote:The forum search ignores words that are 3 characters or less.TheStinkyHippy wrote:Excellent tip. I often struggle on searches,
e.g. if you search for engine AND oil
many results don't have oil in the thread at all.. never understood why
If you search for oil on it's own then you get no results.
If you search for oil leak even with all terms selected it will ignore oil and just search for leak
If you search for oil AND leak again it will ignore oil.
The only way I have found is to search for "oil leak" but then it needs to find the phrase.
Would be handy if there is a forum setting which could allow 3 letter searches. There are quite a lot of 3 letter words related to cars which you just can't search for:
oil
car
air
fan
ecu
etc
the Power of Search
Moderator: Ian
Re: the Power of Search
- g8dhe
Both the minimum and the maximum character count can be changed, however, the index has to then be re-created .....
this can take a long time...
a board with 350 posts took 30seconds this board currently has 270131 so about 6 hours as a minimum I suspect, possibly 12-18 hours more likely!
Jeebers what technology are we using! Useful facts and figures mind you!g8dhe wrote:Both the minimum and the maximum character count can be changed, however, the index has to then be re-created .....
- g8dhe
Re-indexing databases is not done lightly on any technology when the database is of any size!
oil+leak (rather than oil and leak) works
Regards,
Brian.
Regards,
Brian.
- g8dhe
Now count the items (or pages of items) and repeat with just "leak" count again ....
Takes me back to the old days when I designed database apps and was always looking for the best b-tree indexing engine. But of course search engines of the sort used on here must I guess be doing clever indexing of all words and their location in posts, which is a HUGELY more demanding exercise than the simple A-Z 0-999999 etc indexing of date fields like wot I wuz doing.g8dhe wrote:Re-indexing databases is not done lightly on any technology when the database is of any size!
My point was, Geoff, that it recognized oil despite the three character limit
Regards,
Brian.
Regards,
Brian.
- g8dhe
Well not quite, what it does is search for "filter" but highlights both "oil" and "filter" so it will miss messages with just "oil" in them, but any that happen to have "oil" will be highlighted - hope that makes sense!
for 'filter' read 'leak'?g8dhe wrote:Well not quite, what it does is search for "filter" but highlights both "oil" and "filter" so it will miss messages with just "oil" in them, but any that happen to have "oil" will be highlighted - hope that makes sense!
