Parts No Longer Available
If a vehicle is manufactured within the EU there is an obligation by manufacturers to make parts available for 10 years. No such obligation exists for vehicles made outside the EU, and increasingly we may find that parts for Bongos & fredas are no longer available. This is starting to happen for early models (95/96) and I will list here any parts we know that are no longer available.
Aircon Evaporator (Compressor) EPC 6150A Part S09A61J10
Anti Roll Bar Drop Link Brackets (front) 3410A S10H34155
Catalytic Convertor (V6) 6600A J5032060A
Mudflaps Front S09AV3450
Mudflaps Rear S09AV3460
Insect Screens S09AV3520A
Aircon Tank 6130A S09A61500
Transmission Control Unit (2003) WLF8189E1A
Tailgate Studs B46768AC3
Roof Liner Studs 6800C GM0968049
Vacuum Pump 1375C WL0118G00
Aircon Flexible Hoses 6130A S09C61461A & S09C61462A
Torque Converter 1910C BV8019100
Fuel Pump for 97 Diesel 1362C WL0413800D
Gear Change Cables (Manual Transmission) 4600A S09L46500B
Wheel Arch Trim (optional extra) S09AV3140
Aircon O Rings 76-713F H00176751 replaced by S33P61J17
Sill, offside front bottom (beneath driver door) EPC5340A S05B70271B/C
Rear Internal Light Lens Cover (inside tailgate) EPC 5125A S09A51441
Reversing Mirror (Glass Only) EPC 6900A S36069123
Sump Plug HE031040A
Air Hose for 2 litre EPC 1330A FEMJ13752
Rear Prop Shaft for 4WD EPC 2505B P0D25100
Coil Spring Rubber EPC 2800A S10H28012
Dipstick (V6) JE4810450
Brake Pipe EPC4360B S05B45370B
Anti Roll Bar Bracket (front) EPC3410A S10H34155
Latest addition in bold. Last updated 12/03/24
Sump Plug HE031040A
Re: Parts No Longer Available
This is very useful info Ian and thanks++
I'm going to be interested in a replacement AFT roof rubber gasket/seal before long. It will be interesting to see if they are still available.
Airco flexible hoses no longer available
Bye bye Torque Converter for diesel autobox
So I'm about to buy another Bongo, but this does hit home that Bongos are a dying breed. Hmmmm...
Really? I thought I heard once it was the same autobox as fitted to London taxis. Urban myth? What's the workaround, short of a complete autobox from a breaker?Ian wrote:Bye bye Torque Converter for diesel autobox
We'll just have to strap them up in lock up mode!Ian wrote:Bye bye Torque Converter for diesel autobox
Frank
They flew, I took up naturism
Complete fuel pump for 97 Diesel? Forget it!
Don't they just refurbish old ones? What would make this thread really interesting is if a workaround could be posted for each no long available part. Otherwise, peeps might feel a sense of (unjustified?) hopelessnessIan wrote:Complete fuel pump for 97 Diesel? Forget it!
Yes the trend is/was to use refurbished injector pumps, the price of a new IP would make your wallet cringe..
Plastic wheel arch trim no longer manufactured, but copies are available on eBay
Aircon O rings added to list. Which could be a hassle.
Really? I'd hoped these might be a standard item and not specific to Bongo? Anyone care / able to comment?Ian wrote:Aircon O rings added to list. Which could be a hassle.
- g8dhe
We would need to know the diameter and thickness I guess, along with profile if not circular ?
