How to remove rear ac unit and heater to make space
BILLFACE
Post by BILLFACE » Wed Mar 21, 2012 10:21 pm
Hi everyone just stripping out my bongo and trying to work out how to remove rear ac and heater any advice would be great. I need to free up space for fridge and water tank.
Re: How to remove rear ac unit and heater to make space
Post by Northern Bongolow » Thu Mar 22, 2012 6:09 am
http://www.igmaynard.co.uk/bongo/forum/ ... =3&t=29530.
this will help a little. :) disregard the title, it does get interesting :wink:
Last edited by Northern Bongolow on Thu Mar 22, 2012 6:15 am, edited 1 time in total.
Rebiam
Post by Rebiam » Wed Mar 20, 2013 11:50 am
top tip - thanks for the link.
'98 Green over Silver 4WD AFT
Everyone has a photographic memory. Some don't have film.
Post by Simon Jones » Wed Mar 20, 2013 1:56 pm
Removed mine in preparation for fitting Eberspacher heater. There is a lot of space you can make use of once all the gubbins are out the way:
Blanking the A/C by cutting the pipe, crimping the end & brazing it closed with aluminium rod:
Bypassing the cooling system:
New Forest Terrier
Post by New Forest Terrier » Thu Mar 21, 2013 12:54 am
Probably asking the absolute obvious, but will the rear air conditioning work after the rear heater has been taken out of the coolant circuit following a leak. I never use it, the front is enough or if really hot I open the sun roof. I had a drenched passenger on Sunday who wondered if it would help drying out soggy football kit and I just turned the front heater up which did the job.
I cannot think of a connection on the rear air conditioning which would require water, but am I missing something?
Post by Simon Jones » Thu Mar 21, 2013 12:59 am
Rear A/C should work fine for cold air even with no coolant flowing.
helen&tony
Post by helen&tony » Thu Mar 21, 2013 5:28 am
Yes...rear aircon works when by-passing or removing the heater matrix...I've been running like that for a couple of years. I shall remove the whole box in the warm weather and replace the matrix with an all-metal one I have in stock!!!! The old matrix suddenly lost the plastic stubs with no warning...LCA screamed, and I stopped within 100 yards...and only 7 Klix from home, so not even warm!!!!!!
If reconditioning the whole cooling system, it's REALLY worth while swapping the matrix for a metal one...I've taken a matrix to pieces, and the old stubs go almost crystalline with age!!!!
