rear door ladder
Moderator: Ian
- grey fellah
- Bongonaut
rear door ladder
hi, anyone got an ingenious idea how 2 fit a mk1 terzo rear ladder (where you remove the left hand horizontal handle on the rear door) on a 2002 rear door (no handles)
Re: rear door ladder
Self tapping screws then
Into plastic trim panel with light fittings? Fine as long as never used to to climb on or the tailgate is never slammed shut
The facelift tailgates are different under the trim panels so the only practical solution to fit that ladder to that vehicle would be to swap the whole tailgate.
This is the mounting point for the early ladder:
- grey fellah
- Bongonaut
thanks for the repies, guessed it wasn"t an easy fix, not going to drill rear door, so next request, anyone know if i can get hold of the bottom clamps, thanks
You need to get the correct ladder. The one you have is shorter that the correct one as can be seen if you compare the length in these two pictures:
I've got two in the shed which are due to be vapour blasted and powder coated back to new condition as i did with this one. However, I've got a few more pressing things to attend to first so it won't be done for a few months yet but I can give you a shout nearer the time if you're still looking.
- grey fellah
- Bongonaut
thanks simon for your lnfo, i will look for a mk2 ladder & move on the mk 1 set i bought on e bay after a few drinks on a friday night ! lesson learnt !
- Apprentice Bongonaut
Please let me know when you've got round to doing up one of those MK2 ladders! Looks fantastic blasted and coated - have just fitted a solar panel so having a ladder on the back could prove useful for keeping it clean etc. Thanks
Will do
Are you able to climb up those ladders or are they for show?
One of those ladders would be really useful when I want to put surf boards on the roof, but can the roof take a person's weight moving around on top? I would need to get to the front roof bar to tie the boards down. I'm only little, so I don't weigh too much!
Gareth
1999 2.5V6 AFT
1999 2.5V6 AFT
I'm relatively light but wouldn't risk getting on the roof. If it were me, I'd get a cheap telescopic ladder like this so you could access this from any side: https://www.buydirect4u.co.uk/product/d ... tAodLgEAdA
Don't even think about itgarethjr wrote:One of those ladders would be really useful when I want to put surf boards on the roof, but can the roof take a person's weight moving around on top? I would need to get to the front roof bar to tie the boards down. I'm only little, so I don't weigh too much!
