bongoroy63 wrote:A few questions regarding your purchase of the roof rubber seal:Puma931 wrote:Yes, I ordered 8m and fitted it, but got stuck at the back as it was too tight to fit and not enough space to hit with a mallet, so I did not bother with the final part above the tailgate.TheStinkyHippy wrote:Did you replace the rubber around the roof in the end?
http://www.woolies-trim.co.uk/p-1606-fl ... -seal.aspx
1/ was 8mts the right length to buy? Yes
2/ is this a like for like replacement or is it different in any way? not exactly the same, but sits well (the gripper is quite tight, so you need to use a mallet)
3/ is it not possible to undo the bolts on the back of the roof and lift it a bit to fit it on? It appears so
4/ is it a good fit? Yes
5/ what was the length of delivery? 8m
My Bongo has just gone in for a respray and the rubber is looking shabby and cracking in places. I want to replace mine to finish it off.
Project - Retrim and new paint
Moderator: Ian
Re: Project - Retrim and new paint
See below
- Simon Jones
I'm guessing the question referred to how long it took to be deliveredPuma931 wrote:See below
Just ordered 8m myself. Total cost £42.47.
Also ordered some rustoleum matt black to do the roof.. hopefully get out tonight to halfords and buy some bumper filler to start filling the scratches in the roof.
Can I remove the old rubber and leave the roof like that?
I guess if I drive in the rain the roof will get wet.. but can i drive in the dry without the roof seal?
A couple of days
Simon Jones wrote:I'm guessing the question referred to how long it took to be deliveredPuma931 wrote:See below
I woudnt drive with out the roof rubber
It will let the wind in and might damage / lift the roof
Be safe wear a rubber
As Simon has correctly pointed out, yes I meant the delivery time. I was obviously the only person who didn't spot my deliberate mistake!!
Still want to know though if the fit is good before I buy.
I can, I do, I did.
I'll take some close up pictures tonight.
bongoroy63 wrote:As Simon has correctly pointed out, yes I meant the delivery time. I was obviously the only person who didn't spot my deliberate mistake!!
Bitten the bullet and ordered the rubber seal from Woolies. Hopefully will be here in the next couple of days. Seems a bargain at that price.
I can, I do, I did.
I love the Ring and when I lived in Germany I owned a lovely E36 M3 GT
bongoroy63 wrote:Bitten the bullet and ordered the rubber seal from Woolies. Hopefully will be here in the next couple of days. Seems a bargain at that price.
Wow what service from Woolies. I only ordered the rubber seal yesterday morning and it arrived today. Can't wait to put it on.
I can, I do, I did.
- Simon Jones
Their pick n mix used to be awesome too .bongoroy63 wrote:Wow what service from Woolies. I only ordered the rubber seal yesterday morning and it arrived today. Can't wait to put it on.
Just a quick update...
Been using the bongo quite a bit and have been on a couple of camping trips. The hot days have tested the interior trimming I did as some of the vinyl has started to peel away, so I need to find a better contact adhesive. The rustoleum paint still looks good but there are a few rust spots bubbling through on the arches and sill, so they will need some work. I'm also thinking of painting it white with green as the grey looks a bit like primer. Project for later this year....
