Double DIN
Moderator: Ian
Observer
Double DIN
Post by Observer » Sun Nov 04, 2012 3:52 pm
Hi All, I thought I'd treat 'Our Bren' to something like this. http://www.ebay.co.uk/itm/XTRONS-TD714G ... 232356ef77
She already has a basic Extrons DVD player which can also 'forward' DVD movies to her rear drop down screen but we really need Bluetooth for our mobiles, and also the GPS - and ideally the ability to receive Long wave radio stations.
The original Mazda radio/tape player is still filling the lower part of the double DIN hole and I've heard a few horror stories of folk trying to get this part out.
So, has anyone had any experience of fitting a modern double DIN unit in their Bongo?
Cheers Pete
My iPhone - My office
Colin H F
Re: Double DIN
Post by Colin H F » Sun Nov 04, 2012 4:31 pm
Hi dont know if you have noticed but it has only got analogue TV which is of no use here you need DIGITAL like mine see my posts plus its from Japan so you will encounter import and customs costs check it out first
http://www.ebay.co.uk/itm/Erisin-ES996G ... 0925421320?
Observer
Re: Double DIN
Post by Observer » Sun Nov 04, 2012 5:06 pm
Now that looks interesting =D> I'll check it out
Observer
Re: Double DIN
Post by Observer » Tue Nov 13, 2012 1:18 pm
Colin H F wrote:Hi dont know if you have noticed but it has only got analogue TV which is of no use here you need DIGITAL like mine see my posts plus its from Japan so you will encounter import and customs costs check it out first
This could be be what I'm after. Were there any issues removing the old kit and was it just a case of swapping the leads over? How good is the TV reception and would I need a 12v free view gadget?
Cheers Pete
Colin H F
Re: Double DIN
Post by Colin H F » Tue Nov 13, 2012 3:02 pm
Hi on my Ford Freda there was a metal bracket tack welded to the big round bar that is at the back of the din hole, on investigation I found it was a stiffener for the fascia molding [2 Philips screws] this bar was not on my previous Bongo so I removed it just in case I needed a bit more depth turns out I didn't need it anyway, I bought an ISO adapter off the auction site on the web just a couple of quid and it fitted perfectly. as for the DTV works perfectly with the little aerial supplied but as you know reception varies from place to place and weather conditions can effect digital signals, it has a removable screen and the clever bit is when it is removed the radio still plays the last station you were tuned into.but all in all I am well pleased
rapiddescent
Re: Double DIN
Post by rapiddescent » Tue Nov 13, 2012 9:11 pm
I never thought of cutting that bit off. i just drilled a bigger hole in it so I could add in another cable. I have a seperate freeview box located in the glovebox - it's one of the ebay 12v specials (that can even record to USB when you're "out") but mine seems to only get the BBC channels. I do need to have a closer look at it sometime.
here's my instructions: http://www.igmaynard.co.uk/bongo/forum/ ... 44&t=38039
Ford Freda owning mountain biker dude
mantaJim
Re: Double DIN
Post by mantaJim » Tue Nov 13, 2012 11:02 pm
I had an xtrons td717 back in february - it went back several times for repair and I had to pay courier costs each time apart from once when the seller (apparently xtrons agent under an eBay user name) begrudgingly collected at at their own cost when I got shirty. Eventually they agreed I could return it but withheld £20 due to wear and tear - as they expected 6 months down the line having had virtually no use from the equipment I just wanted rid and any money back seemed a result even though with costs I was £60 down. I now have a rock solid dependable kenwood - it's a shame I can't say that about my bongo engine :cry:
Suggest You google xtrons reviews, problems etc and see the results...i wish I had
V6 Mushroom
Observer
Re: Double DIN
Post by Observer » Wed Nov 14, 2012 11:13 am
rapiddescent wrote:I never thought of cutting that bit off. i just drilled a bigger hole in it so I could add in another cable. I have a seperate freeview box located in the glovebox - it's one of the ebay 12v specials (that can even record to USB when you're "out") but mine seems to only get the BBC channels. I do need to have a closer look at it sometime.
That's it =D> =D> a tutorial =D> Now I can get back to ebay
Cheers Pete
Observer
Re: Double DIN
Post by Observer » Fri Nov 30, 2012 1:09 pm
PM sent
Colin H F
Re: Double DIN
Post by Colin H F » Fri Nov 30, 2012 4:20 pm
PM sent
who to
Observer
Re: Double DIN
Post by Observer » Fri Nov 30, 2012 5:22 pm
PM sent
who to
err, you I thought :mrgreen:
jimpearceuk
Re: Double DIN
Post by jimpearceuk » Tue Feb 19, 2013 1:26 am
Here is my setup ... shout if you have any questions
http://igmaynard.co.uk/bongo/forum/view ... 88#p482351
Observer
Re: Double DIN
Post by Observer » Sat May 04, 2013 10:08 am
jimpearceuk wrote:Here is my setup ... shout if you have any questions
Hi you mention a 128db gain aerial mouinted behind the mirror where did you buy it?
Return to “Pimp My Bongo”
