reversing sensor not working
can any one give any help on reversing sensors, mine was working fine but now i only have the little red light on(so presume it has power going to it), now beeping and no numbers to show distance. Thanks
Re: reversing sensor not working
Hello. I cannot advise on your unit unfortunately but I have installed a set on my bongo which were bought on Amazon for under £20 which wire into the reversing light wire and operate a small alarm installed behind the rear panel. Very easy to fit. So if your unit proves expensive to repair this may be an alternative option.
What vehicle do you own ?.
Mine is a 2001 areo city runner 2.0lt.
