van playing up
van playing up
Hi All of you out there that know the way around the vans my playing me up just a bit
keep getting glowplug wraning litghts flashing on and then we drop in to lip home mode wich not to bad but need to get it sorted soon well i booked in to a work shop this week there ask up front if there is a map to show the Vacuum i taken there mean one that would show waste geat and egr /ecu is there one out there online ?
take it easy drive a bongo
Re: van playing up
what year and engine is your bongo alan.
does he want an electrical vac (map), or a pipework vac plan.??
Re: van playing up
no there changed there mine say there neeed a wire map of the bongo with a 4 plug ecu
starting to think there missing me about and time to look ealse were
Re: van playing up
Northern Bongolow wrote:what year and engine is your bongo alan.
Re: van playing up
ask them to check the egr solenoids on the driverside chassis leg under the drivers seat,or the egr valve itself, or the turbo wastegate.
Re: van playing up
Northern Bongolow wrote:ask them to check the egr solenoids on the driverside chassis leg under the drivers seat,or the egr valve itself, or the turbo wastegate.
Re: van playing up
Re: van playing up
ok codes are p400 egr flow malfuncions
p1228 waste gate
this is want there say there found so far ecu is telling trubo to shut down so lak of power
Question was ask why this happening answer we dont know need wire map; tro make sure not ecu
me think there a swhich that been tlod to trun this on and of and its that swhich is want fualty
p1228 waste gate
Re: van playing up
the egr switches are under the drivers seat on the chassis rail. if the solenoids fail it leaves the egr valve in the wrong position (it has a position sensor on it) this tells the ecu its faulty so goes into limp mode via the ecu/turbo. if you fix the solenoid it will clear the egr fault and restore your turbo.-----------------------------------------------maybeNorthern Bongolow wrote:ask them to check the egr solenoids on the driverside chassis leg under the drivers seat,or the egr valve itself, or the turbo wastegate.
