Well just replaced the top seal on the powered steering as it was leaking and the third MOT is due.
I did it all from the top as in under the bonnet. Took the air inlet pipe off, undid the two 12mm bolts holding the universal joint from the steering column to the rack. Knocked the joint up and it then came off so put it out of the way. Dust cover off then how to get the old seal out. There is a circlip holding it in so oh bugger don’t have any circlip pliers
, well some long nose pliers managed to get it out. Now the seal!!!! With the help of a small bladed screwdriver managed to lever it out. Pushed the new one in (make sure all the gubbings below is well seated first by pushing down with a blunt screwdriver. Located the new seal with a tap of a hammer on a long reach socket. Refitted the circlip, the dust seal and universal joint and Bob’s you uncle job done in less than an hour.
Just got to reset the steering wheel as it’s upside down when going in a straight line
