I tapped into the same live wire (green/yellow) Going through the rubber membrane where the drive shift thing goes trough under the glory hole following the accelerator cable to where the 2 wires for the scav fan split from the main loom..
Then making a small hole just where it splits at the main loom i ran the wire down inside the loom cover to the bottom where it was easier to tap into the wire just above the connector to the fan & taping the whole thing back up like it never happened...!
Lucky i have an inspection pit, you really need to get the vehicle up off the floor in order to get at it...
I fitted a blue led to flash for the alarm, & some reds in a faulty gutted plasma dial that the gauge company didn't want back during a replacement... (left hand gauge in the glory hole cover.) Now the reds light up when i lock momentarily (about 4 seconds) off the second channel of the mirror fold module then the blue alarmed light flash takes over...
I also have another fake alarm led pulse box in line with the red leds, which is what causes em to flash if the scav fan comes on..!
   Up for a bit of a brain picking at the big bash mate?
