Lever behind air intake...what it for?
AeroNut
Post by AeroNut » Tue Mar 22, 2011 2:00 pm
Hi, can I have some info please?
There is s lever behind the air intake under the bonnet which can be put in 2 positions. Can someone tell me what it's for and what position should it be in? Thanks
Terry
wonkanoby
Re: Lever behind air intake...what it for?
Post by wonkanoby » Tue Mar 22, 2011 2:30 pm
forward for normal climate & back for cold climate
AeroNut
Post by AeroNut » Wed Mar 23, 2011 7:37 am
AH HA!...
Thank you very much
Regards
Terry
nelshaun
Post by nelshaun » Thu Jan 19, 2012 7:32 am
Thanks for the this one. I'm also puzzled with the use of this one. By the way, will a new ram air intake affect the process if I get a new one?
Post by Simon Jones » Thu Jan 19, 2012 2:28 pm
Bear in mind, the lever is for the air intake to the vehicle interior for heating / cooling and nothing to do with the engine air intake.
Darkstar
Post by Darkstar » Fri Jan 20, 2012 7:55 pm
if you have a digital heater control, you will find a small servo inside the intake connected to the lever from inside, and should close the intake when you use re-circulate.
Got a Bongo for the Wife, Best trade-in ever
j333.vrs@wimanx.net
Post by j333.vrs@wimanx.net » Sat May 10, 2014 12:28 pm
forward ? or backwards ?
towards the front of the vehicle for summer setting or towards the bulkhead ?
confused ?
Post by rita » Sat May 10, 2014 1:04 pm
Its a cold climate control lever, push the lever towards the bulkhead (rear of vehicle) for Cold climate. Push the lever towards the radiator (front of the vehicle)for normal lovely English weather.
