Has anyone had or can recomend a place in Cardiff area to carry out aircon top up/refurb?
I have no idea if my van has ever had this work done so I wouldnt mind getting it working as it should ready for summer.
I have also heard though that you can start a whole lot of problems if it is not done right!!
Air Con
Re: Air Con
I got it done by a mobile guy, but can't remember his details sadly. I helped out by removing a few bits of the front end to provide easy access to the input valve before he arrived. He also did a check for leaks (and found one). Instead of charging me twice, he charged me part of the cost once he'd checked the system for leaks, removed the gas/oil and came abck once I'd fitted a new condensor before charging the rest.
Beyond A to B
